Net Refrigeration Effect
The quantity of heat absorbed from a refrigerated space.
Net Refrigeration Effect is
"the quantity of heat that each pound of refrigerant absorbs from the refrigerated space to produce useful cooling"
Net Refrigeration Effect can be calculated as
NRE = h l - h e (1)
NRE = Net Refrigeration Effect (Btu/lb, J/kg)
h l = enthalpy of vapor leaving evaporator (Btu/lb, J/kg)
h e = enthalpy of vapor entering evaporator (Btu/lb, J/kg)
  • Air Conditioning Systems
  • The Engineering ToolBox (2010). Net Refrigeration Effect. [online] Available at: https://www.engineeringtoolbox.com/net-refrigeration-effect-d_1667.html [Accessed Day Month Year].
