Refrigeration Formulas
Calculate compression work, coefficients of performance and more.
Compression Work
Compressor work can expressed as
W = h q                                                    (1)
W = compression work (Btu min)
h = heat of compression (Btu/lb)
q = refrigerant circulated (lb/min)
Compression Horsepower
Compression horsepower can be expressed as
P = W / 42.4                                                (2)
P = compression power (hp)
Alternatively
P = c / (42.4 COP)                                          (2b)
c = capacity (Btu/min)
COP = coefficient of performance
Compression horsepower per Ton
p = 4.715 / COP                                             (2c)
p = compressor horsepower per Ton (hp/Ton)
COP - Coefficient of Performance
COP = NRE / h                                            (3)
COP = Coefficient of Performance
NRE = Net Refrigeration Effect (Btu/lb)
Net refrigeration effect can be expressed as
NRE = h l - h e (4)
h l = enthalpy of vapor leaving evaporator (Btu/lb)
h e = enthalpy of vapor entering evaporator (Btu/lb)
Capacity
c = q NRE                                                  (5)
Compressor Displacement
d = c v / NRE                                             (6)
d = compressor displacement (ft3 /min)
v = volume of gas entering compressor (ft3 /lb)
Heat of Compression
h = h lc - h ec (7)
h lc = enthalpy of vapor leaving compressor (Btu/lb)
h ec = enthalpy of vapor entering compressor (Btu/lb)
Volumetric Efficiency
μ = 100 w a / w t (8)
μ = volumetric efficiency
w a = actual weight of refrigerant
w t = theoretical weight of refrigerant
Compression Ratio
CR = p h / p s (9)
CR = compression rate
p h = head pressure absolute (psia)
p s = suction pressure, absolute (psia)
  • Air Conditioning Systems
  • The Engineering ToolBox (2010). Refrigeration Formulas. [online] Available at: https://www.engineeringtoolbox.com/refrigeration-formulas-d_1695.html [Accessed Day Month Year].
