Compressed Air - Pipe Line Pressure Drop Diagram
Calculate pressure drop in compressed air pipe lines with a nomograph diagram.
The nomograph diagram below can be used to estimate pressure drop in compressed air pipe lines:
compressed air pressure drop diagram nomograph
Download and print Compressed Air - Pipe Line Pressure Drop Diagram
Example - Pressure Drop in Compressed Air Pipeline
The pressure drop in a compressed air pipe line
  • length 100 m
  • air flow 500 l/s
  • inside diameter 100 mm
  • working pressure 9 bar gauge
can be estimated in the diagram by drawing a line from the length line through the air flow volume line to the reference line. From the point on the reference line draw a line through the pipe diameter line to the reference line. From the working pressure line draw a line through the point on the reference line to the pressure drop line.
As indicated below the pressure drop can be estimated to 0.07 bar.
compressed air pressure drop diagram nomograph example
  • The Engineering ToolBox (2008). Compressed Air - Pipe Line Pressure Drop Diagram. [online] Available at: https://www.engineeringtoolbox.com/compressed-air-pressure-drop-nomograph-d_1278.html [Accessed Day Month Year].
