Wood - Density vs. Moisture Content
The density of wood versus moisture content.
Density of wood versus content of water can be calculated as
ρ = 62.4 (SG / (1 + SG 0.009 m))(1 + m / 100)                                                    (1)
ρ = density of wood (lb/ft3)
SG = Specific Gravity of wood
m = moisture content in wood (%)
  • 1 lb/ft3  = 16.018 kg/m3 = 0.016 g/cm3 = 0.00926 oz/in3 = 2.57 oz/gal (Imperial) = 2.139 oz/gal (U.S.) = 0.0005787 lb/in3 = 27 lb/yd3 = 0.161 lb/gal (Imperial) = 0.134 lb/gal (U.S) = 0.0121 ton/yd3
  • Densities
  • The Engineering ToolBox (2010). Wood - Density vs. Moisture Content. [online] Available at: https://www.engineeringtoolbox.com/wood-density-d_1616.html [Accessed Day Month Year].
