Wire Size - Area to Diameter Converter
Convert wire area from square mm to diameter mm.
Use the table below to convert between wire square mm and diameter mm:
mm2mm
0.75 1.0
1 1.1
1.5 1.4
2 1.5
2.5 1.8
4 2.3
6 2.8
10 3.6
16 4.5
25 5.6
35 6.7
50 8.0
70 9.5
95 11.0
120 12.4
150 13.8
185 15.4
240 17.5
300 19.5
400 22.6
500 25.2
630 28.3
800 31.9
1000 35.7
1200 39.1
2000 50.5
Wire - diameter mm to area square mmDownload an print mm to mm2 diagram
  • Electrical
  • The Engineering ToolBox (2014). Wire Size - Area to Diameter Converter. [online] Available at: https://www.engineeringtoolbox.com/wire-square-mm-diameter-d_1874.html [Accessed Day Month Year].
