Staircases Calculator
Calculate steps, unit rise and run in a staircase.
The calculator can be used to calculate unit rise and run of straight stairs.
stair - unit run and rise calculator
  • Unit rise:
  • Unit run:
  • Elevation angle: degrees
  • Offset steps:
General guidelines
  • unit run should not be less than 10 inches (25 cm)
  • unit rise should not exceed 7 3/4 inches (20 cm)
Add 3D Stairs to Sketchup Models
Add 3d stairs to Sktechup models
  • The Engineering ToolBox (2008). Staircases Calculator. [online] Available at: https://www.engineeringtoolbox.com/stairs-calculator-d_1372.html [Accessed Day Month Year].
