Building Tolerances
Typical tolerances for floors, walls, columns and more.
waterpass building tolerances
Typical building tolerances are indicated below:
Floors, Flatness
Measured over a 3 m long straight edge:
  • Concrete, in situ : 5 mm
  • Floor screed : 5 mm
Wall Vertical
  • Brickwork : 10 mm
  • Blockwork : 10 mm
  • Concrete, in situ : 17 mm
  • Concrete, precast : 11mm
Column Vertical
  • Steel : 6 mm
  • Timber : 10 mm
  • Concrete, in situ : 12 mm
  • Concrete, precast : 10 mm
Space between Walls
  • Brickwork : 20 mm
  • Blockwork : 21 mm
  • Timber : 30 mm
  • Concrete, in situ : 24 mm
  • Concrete, precast : 18 mm
Space between Columns
  • Steel : 12 mm
  • Timber : 12 mm
  • Concrete, in situ : 18 mm
  • Concrete, precast : 13 mm
Beams, Vertical Position
  • Steel : 20 mm
  • Timber : 20 mm
  • Concrete, in situ : 22 mm
  • Concrete, precast : 23 mm
Floors, Vertical Position
  • Concrete, in situ : 15 mm
  • Concrete, precast : 15 mm
Plan Position
  • Brickwork : 10 mm
  • Steel : 10 mm
  • Timber : 10 mm
  • The Engineering ToolBox (2011). Building Tolerances. [online] Available at: https://www.engineeringtoolbox.com/building-tolerances-d_1790.html [Accessed Day Month Year].
