Specific Heat of common Substances
Specific Heat for some common products are given in the table below.
See also tabulated values for gases, food and foodstuff, metals and semimetals, common liquids and fluids and common solids, as well as values of molar specific heat for common organic substances and inorganic substances.
SubstanceSpecific Heat
- cp -
(J/kg C°)
Acetals 1460
Air, dry (sea level) 1005
Agate 800
Alcohol, ethyl 2440
Alcohol, metyl wood) 2530
Aluminum 897
Aluminum bronze 436
Alumina, AL2O3 718
Ammonia, liquid 4700
Ammonia, gas 2060
Antimony 209
Argon 520
Arsenic 348
Artificial wool 1357
Asbestos 816
Asphalt concrete (with aggregate) 920
Barium 290
Barytes 460
Beryllium 1020
Bismuth 130
Boiler scale 800
Bone 440
Boron 960
Boron nitride 720
Brass 375
Brick 840
Bronze 370
Brown iron ore 670
Cadmium 234
Calcium 532
Calsium silicate, CaSiO3 710
Cellulose, cotton, wood pulp and regenerated 1300 - 1500
Cellulose acetate, molded 1260 - 1800
Cellulose acetate, sheet 1260 - 2100
Cellulose nitrate, Celluloid 1300 - 1700
Chalk 750
Charcoal 840
Chromium 452
Chrom oxide 750
Clay, sandy 1381
Cobalt 435
Coke 840
Concrete 880
Constantan 410
Copper 385
Cork 2000
Diamond (carbon) 516
Duralium 920
Emery 960
Epoxy cast resins 1000
Fire brick 880
Fluorspar CaF2 830
Dichlorodifluoromethane R12, liquid 871
Dichlorodifluoromethane R12, vapor 595
Ice (0oC) 2093
India rubber 1250
Glass, crown 670
Glass, pyrex 753
Glass-wool 840
Gold 129
Granite 790
Graphite (carbon) 717
Gypsum 1090
Helium 5193
Hydrogen 14304
Ice, snow (-5oC) 2090
Ingot iron 490
Iodine 218
Iridium 134
Iron 449
Lead 129
Leather 1500
Limestone 909
Lithium 3582
Lucite 1460
Magnesia (Mangnesium oxide), MgO 874
Magnesium 1050
Magnesium alloy 1010
Manganese 460
Marble 880
Mercury 140
Mica 880
Molybdenum 272
Neon 1030
Nickel 461
Nitrogen 1040
Nylon-6 1600
Nylon-66 1700
Olive oil 1790
Osmium 130
Oxygen 918
Palladium 240
Paper 1336
Paraffin 3260
Peat 1900
Perlite 387
Phenolic cast resins 1250 - 1670
Phenol-formaldehyde molding compounds 2500 - 6000
Phosphorbonze 360
Phosphorus 800
Pinchbeck 380
Pit coal 1020
Platinium 133
Plutonium 140
Polycarbonates 1170 - 1250
Polyethylene terephthalate 1250
Polyimide aromatics 1120
Polyisoprene natural rubber 1880
Polyisoprene hard rubber 1380
Polymethylmethacrylate 1500
Polypropylene
1920
Polystyrene 1300 - 1500
Polytetrafluoroethylene moulding compound 1000
Polytetrafluoroethylene (PTFE) 1172
Polyurethane cast liquid 1800
Polyurethane elastomer 1800
Polyvinylchloride PVC 840 - 1170
Porcelain 1085
Potassium 1000
Potassium chloride 680
Pyroceram 710
Quartz, SiO2 730
Quartz glass 700
Red metal 381
Rhenium 140
Rhodium 240
Rosin 1300
Rubidium 330
Salt, NaCl 880
Sand, quartz 830
Sandstone 710
Scandium 568
Selenium 330
Silicon 705
silicon carbide 670
Silver 235
Slate 760
Sodium 1260
Soil, dry 800
Soil, wet 1480
Soot 840
Snow 2090
Steatite 830
Steel 490
Sulfur, crystal 700
Tantalium 138
Tellurium 201
Thorium 140
Timber, alder 1400
Timber, ash 1600
Timber, birch 1900
Timber, larch 1400
Timber, maple 1600
Timber, oak 2400
Timber, pitchpine 1300
Timber, pockwood 2500
Timber, red beech 1300
Timber, red pine 1500
Timber, white pine 1500
Timber, walnut 1400
Tin 228
Titanium 523
Tungsten 132
Tungsten carbide 171
Uranium 116
Vanadium 500
Water, pure liquid (20oC) 4182
Water, vapor (27oC) 1864
Wet mud 2512
Wood 1300 - 2400
Zinc 388
  • 1 calorie = 4.186 joules = 0.001 Btu/lbm oF
  • 1 cal/gram Co = 4186 J/kgo
  • 1 J/kg Co = 10-3 kJ/kg K = 10-3 J/g Co = 10-6 kJ/g Co= 2.389x10-4 Btu/(lbm oF)
For conversion of units, use the Specific heat online unit converter.
  • The Engineering ToolBox (2003). Specific Heat of common Substances. [online] Available at: https://www.engineeringtoolbox.com/specific-heat-capacity-d_391.html [Accessed Day Month Year].
