Smaller Rectangles within a Larger Rectangle
The calculator below can be used to estimate the maximum number of smaller rectangles - or squares - that may fit into a larger rectangle or square. The calculator can be used to calculate applicatons like
  • the number of bricks in a wall
  • the number of rectangular cuts possible from a steel or plywood plate
Input the large rectangle inside dimensions - and the outside dimensions of the smaller rectangles.
Default values are for 0.5 x 0.8 inch rectangle inside a 10 inch x 10 inch square. The calculator is generic and all units can be used - as long as the same units are used for all values.
Rectangular Pattern
Number of smaller rectangles within a larger rectangle
Note! - the algorithm used for this tool is quite simple. Be aware that for some combinations of values more rectangles can be added by rearranging the layout.
  • Mathematics
  • The Engineering ToolBox (2018). Smaller Rectangles within a Larger Rectangle. [online] Available at: https://www.engineeringtoolbox.com/smaller-rectangles-within-larger-rectangle-d_2111.html [Accessed Day Month Year].
