Noise Attenuation in Rotary Heat Exchanges
Sound attenuation vs. frequency in rotating heat exchangers.
Noise attenuation in rotary heat exchangers:
Frequency
(Hz)
631252505001000200040008000
Attenuation
(dB)
2 2 3 4 5 7 8 9
Note that larger inlet or outlet chambers should be calculated separate.
  • Noise and Attenuation
  • The Engineering ToolBox (2008). Noise Attenuation in Rotary Heat Exchanges. [online] Available at: https://www.engineeringtoolbox.com/rotary-heat-exchanger-noise-attenuation-d_1406.html [Accessed Day Month Year].
