Valves - Normally Closed (NC)
Valves and the term Normally Closed.
The term Normally Closed (NC) applies to manual valves or dampers which the operator must leave closed in normal operation.
A control valve that should go to a closed position on a control signal failure should be labeled FC, i.e. Fail-Closed. The control signal may be pneumatic, hydraulic or electric.
  • Control Valve Sizing
  • The Engineering ToolBox (2005). Valves - Normally Closed (NC). [online] Available at: https://www.engineeringtoolbox.com/nomally-closed-d_879.html [Accessed Day Month Year].
