Valves - Fail-Closed (FC)
A control valve that goes to closed position if control signal or air fails.
A control valve which should go to closed position on control signal failure should be labeled
  • FC - Fail-Closed
The control signal may be pneumatic, hydraulic or electric.
  • Control Valve Sizing
  • The Engineering ToolBox (2008). Valves - Fail-Closed (FC). [online] Available at: https://www.engineeringtoolbox.com/fail-closed-d_1044.html [Accessed Day Month Year].
