Valves - Fail-Last (FL)
A control valve that should stay put if control signal or air fails.
A control valve which should stay put on the position on control signal failure should be labeled
  • FL - Fail-Last
The control signal may be pneumatic, hydraulic or electric.
  • Control Valve Sizing
  • The Engineering ToolBox (2008). Valves - Fail-Last (FL). [online] Available at: https://www.engineeringtoolbox.com/fail-last-d_1046.html [Accessed Day Month Year].
