Valves - Fail-Open (FO)
A control valve that goes to open position if control signal or air fails.
A control valve which should go to the open position on control signal failure should be labeled
  • FO - Fail-Open
The control signal may be pneumatic, hydraulic or electric.
  • Control Valve Sizing
  • The Engineering ToolBox (2008). Valves - Fail-Open (FO). [online] Available at: https://www.engineeringtoolbox.com/fail-open-d_1045.html [Accessed Day Month Year].
