Conservation of Momentum
The momentum of a body is the product of its mass and velocity - recoil calculator.
Linear Momentum
The momentum of a body is defined as the product of its mass and velocity. Since velocity is a vector quantity - momentum is a vector quantity.
Momentum - body mass and velocity
The momentum of a body can be expressed as
ML = m v                                      (1)
ML = linear momentum (kg m/s, lb ft/s)
m = mass of body (kg, lb)
v = velocity of body (m/s, ft/s)
The momentum of a body remains the same as long as there is no external forces acting on it. The principle of conservation of momentum can be stated as
the total linear momentum of a system is a constant
The total momentum of two or more bodies before collision in a given direction is equal to the total momentum of the bodies after collision in the same direction and can be expressed as
ML = m1 v1 + m2 v2 + ..  + mn vn
        =  m1 u1 + m2 u2 + ..  + mn un                                       (2)
v = velocities of bodies before collision (m/s, ft/s)
u = velocities of bodies after collision (m/s, ft/s)
Example - Linear Momentum
A body with mass 30 kg and velocity 30 m/s collides with a body with mass 20 kg and velocity 20 m/s. The velocities of both bodies are in the same direction. Assuming the both bodies have same velocity after impact - the resulting velocity can be calculated as:
   ML = (30 kg) (30 m/s)  + (20 kg)  (20 m/s)
        =  u ((30 kg) + (20 kg))
        = constant
    transformed:
    u = (30 kg) (30 m/s)  + (20 kg) (20 m/s)  /  ((30 kg) + (20 kg))
        = 26 (m/s)
Example - Recoil Velocity after Rifle Shoot
A rifle weighing 6 lb fires a bullet weighing 0.035 lb with muzzle speed 2100 ft/s. The total momentum of the rifle and bullet can be expressed as
ML = mr vr + mb vb
    = mr ur + mb ub
The rifle and the bullet are initially at rest (vr = vb = 0):
ML = (6 lb) (0 ft/s) + (0.035 lb) (0 ft/s)
     = (6 lb) ur (ft/s) + (0.035 lb) (2100 ft/s)
     = 0
The rifle recoil speed:
ur = - (0.035 lb) (2100 ft/s) / (6 lb)
    = - 12.25 (ft/s)
The recoil kinetic energy in the rifle can be calculated as
E = 1/2 m ur2
   = 1/2 (6 lb) (-12.25)2
   = 450 lb ft
The  force required to slow down a recoil depends on the slow down distance. With a slow down distance s = 1.5 in (0.125 ft) - the acting force can be calculated as
F = E / s
  = (450 lb ft) / (0.125 ft)
  = 3600 lb
Recoil Calculator
Angular Momentum
Angular momentum for a rotating body can be expressed as
MR = ω I                          (3)
MR = angular momentum of rotating body (kg m2 / s, lbf ft s)
ω = angular velocity (rad/s)
I = moment of inertia - an object's resistance to changes in rotation direction (kg m2, slug ft2)
The conservation of angular momentum can be expressed as
ω1 I1 = ω2 I2                          (4a)
or
n1 I1 = n2 I2     (4b)
n = rotation velocity in revolutions per minute (rpm)
For a small point mass I = m r2 and ω = v / r and 4a can be modified to
m v1 r1 = m v2 r2                  (4c)
or
v1 r1 = v2 r2                       (4d)
or
ω1 r1 = ω2 r2                          (4e)
or
n1 r1 = n2 r2                          (4f)
v = tangential velocity (m/s, ft/s)
r = radius (m, ft)
Example - Small Sphere
A small iron sphere rotates around an axis with velocity 100 rpm when connected to a rope with length 1.5 m. The rope is extended to 2.5 m and due to conservation of angular momentum the new velocity can be calculated by modifying 4f to
n2 = n1 r1 / r2
    = (100 rpm) (1.5 m) / (2.5 m)
    = 60 rpm
  • Mechanics
  • The Engineering ToolBox (2008). Conservation of Momentum. [online] Available at: https://www.engineeringtoolbox.com/linear-momentum-d_1375.html [Accessed Day Month Year].
