The Engineering ToolBox Web Google
Piping Systems - Corrosion
Corrosion in piping systems - caused by thermodynamic and electrochemical processes - corrosion problems and methods of protection and prevention
Chemical Resistance Polyethylene - PE
Chemical resistance of polyethylene - PEH - pipes
Corrosion Protection of Pipes
Corrosion protection tutorial of piping systems
CPVC - Chemical Resistance
Chemical resistance of CPVC - Chlorinated Poly(Vinyl Chloride) - pipes
Electrode Potential and Galvanic Corrosion
An introduction to the electrochemical series and corrosion of metals
Epoxy - Chemical Resistance
Chemical resistance of Epoxy to common products as Acetic acid, Alcohol, Diesel oil and more
Glossary of Corrosion Related Terms
A glossary of common used terms related corrosion
Identification Tests for Stainless Steels
Magnetic, spark, hardness and acid identification tests of austenitic, martensitic and ferritic stainless steels
Metals and Corrosion Resistance
Common metals and their corrosion resistance to aggressive fluids as acids, bases and more
Oxygen and Steel Pipe Corrosion
Oxygen concentration, temperature and corrosion of steel pipes
Piping Materials & Galvanic Corrosion
Connecting pipes of common piping materials may cause galvanic corrosion and serious damage
Polyester - Chemical Resistance
Chemical resistance of Polyester to common products like Acetic acid, Diesel oil and more
Polypropylene PP - Chemical Resistance
Chemical resistance of PolyPropylene - PP - to some common acids, bases, organic substances and solvents
Thermoplastics and Chemical Resistance
Chemical resistance of ABS, CPVC, PP, PVC, PE, PB, PVDF and PEX piping materials to common chemicals and products ranging from beer, acryl acid, diesel oil and many more
Types of Corrosion
Uniform, pitting, galvanic, crevice, concentration cell and graphitic corrosion
Search the ToolBox
9 11 11
handheld Engineering ToolBox - optimized for mobile devices! 3D Engineering ToolBox - draw and model technical applications!
Resources, Tools and Basic Information  for Engineering and Design of Technical Applications!
