Copper Tubes - Corrosion Resistance to Chemicals
Copper tubes corrosion resistance to different products and chemicals.
Copper Tubes Corrosion Resistance
Copper Tubes are Resistant to Corrosion from
Acetone
Alcohols
Alumina
Aluminium Hydroxide
Ammonia Gas (Dry)
Amyl Acetate
Amyl Alcohol
Asphalt (Dry)
Atmosphere (Rural)
Barium Carbonate
Barium Hydroxide
Barium Sulphate
Beer
Benzene
Benzine
Borax
Bordeaux Mixture
Boric Acid
Bromine (Dry)
Butane
Butyl Alcohol
Calcium Hydroxide
Cane Sugar Syrup
Carbon Dioxide (Dry Gas)
Carbon Tetrachloride (Dry)
Castor Oil
Chlorine (Dry)
Chloroform
Cider
Coffee
Corn Oil
Cottonseed Oil
Creosote
Crude Oil (Low Sulphur)
Drinking Water
Ethers
Ethyl Acetate
Ethyl Alcohol
Ethylene Glycol (Inhibited)
Freon
Fuel Oil
Gasoline
Gelatine
Glucose
Glycerine
Hydrocarbons (Pure)
Hydrogen
Hydrogen Sulphide (Dry)
Kerosene
Lacquers
Lime
Magnesia
Magnesium Sulphate
Methyl Alcohol
Methyl Chloride (Dry)
Milk
Natural Gas
Nitrogen
Oxygen
Paraffin Wax
Potassium Sulphate
Propane
Rosin
Sodium Silicate
Sodium Sulphate
Solvents for Varnish
Steam
Sugarbeet (Syrup)
Sulphur Chloride (Dry)
Sulphuric Anhydride (Dry)
Sulphurous Anhydride (Dry)
Tar (Dry)
Toluene
Trichloroethylene (Dry)
Turpentine
Varnish
Copper Tubes are well resistant to Corrosion from
Acetic (Acid)
Acetic (Acid)
Acetic (Anhydride)
Acetic (Anhydride)
Alum
Alum
Aluminium Chloride
Aluminium Chloride
Aluminium Sulphate
Aluminium Sulphate
Atmosphere (Industrial)
Barium Chloride
Barium Chloride
Butyric Acid
Butyric Acid
Calcium Disulphide
Calcium Disulphide
Carbon Tetrachloride (Wet)
Caustic Soda
Caustic Soda
Copper Sulphate
Copper Sulphate
Ethyl Chloride
Ethyl Chloride
Formaldehyde
Formaldehyde
Formic Acid
Formic Acid
Fruit Juice
Furfural
Glue
Lactic Acid
Linseed Oil
Magnesium Chloride
Oxygenated water
Palmitic Acid
Potash
Potassium Carbonate
Potassium Chloride
Copper Tubes undergoes slow Corrosion from
Aniline (Dyes)
Atmosphere (Marine)
Barium Sulphide
Brine
Bromine (Wet)
Calcium Chloride
Calcium Hypochlorite
Carbolic Acid
Chloroacetic Acid
Citric Acid
Copper Chloride
Copper Nitrate
Ferrous Sulphate
Fluorosilicic Acid
Mine Water (Acid)
Oleic Acid
Oxalic Acid
Phosphoric Acid
Seawater
Sodium Hypochlorite
Sodium Peroxide
Sodium Sulphide
Sulphuric Acid (<40%)
Sulphurous Acid
Tartaric Acid
Trichloroacetic Acid
Vinegar
Zinc Chloride
Zinc Sulphate
Copper Tubes are not Recommended with
Acetylene
Ammonia Gas (Wet)
Ammonium Chloride
Ammonium Hydroxide
Ammonium Nitrate
Ammonium Sulphate
Aniline
Benzoic Acid
Carbon Dioxide (Wet Gas)
Chlorine (Wet)
Chromic Acid
Ferric Chloride
Ferric Sulphate
Ferrous Chloride
Hydrobromic Acid
Hydrochloric Acid
Hydrocyanic Acid
Hydrofluoric Acid
Hydrogen Sulphide (Wet)
Mercury (and its salts)
Nitric Acid
Potassium Cyanide
Silver Salts
Sodium Cyanide
Sodium Hyposulphite
Sulphur (Molten)
Sulphuric Acid (40/80%)
Sulphuric Acid (80/95%)
Note! - corrosion in a piping system may be fatal - always check corrosion resistance of piping material, product and chemical combination with alternative sources.
  • Corrosion
  • The Engineering ToolBox (2018). Copper Tubes - Corrosion Resistance to Chemicals. [online] Available at: https://www.engineeringtoolbox.com/copper-tubes-corrosion-resistance-chemicals-d_2125.html [Accessed Day Month Year].
