Belt driven Fans - Fan vs. Motor Speed
Fan vs. motor speed in belt driven fans.
Belt driven fans are used in heating, ventilation, air-conditioning and cooling (HVAC) systems.
Belt driven fan - pulley and motor velocity
The speed of a fan wheel versus the speed of the motor with a belt drive can be calculated as
df nf = dm nm                          (1)
df = pulley diameter fan (inch, mm)
nf = speed of fan (rpm - rounds per minute)
dm = pulley diameter motor (inch, mm)
nm = speed of motor (rpm - rounds per minute)
Example - Speed of Fan
A synchronous electrical motor rotates with speed 1000 rpm. The motor pulley diameter is 76.5 mm and the fan pulley diameter is 205.5 mm. The speed of the fan can be calculated by modifying (1) to
nf = dm nm / df
- or with values:
nf = (76.5 mm) (1000 rpm) / (205.5 mm)
   = 372 rpm
  • Ventilation Systems
  • The Engineering ToolBox (2005). Belt driven Fans - Fan vs. Motor Speed. [online] Available at: https://www.engineeringtoolbox.com/belt-fan-motor-d_871.html [Accessed Day Month Year].
