Fans - Troubleshooting
Guide to troubleshooting fan problems.
Excessive Vibration and Noise
  • Belts too loose - worn or oily belts
  • Speed too high
  • Damaged or unbalanced wheel
  • Bearings need lubrication or replacement
  • Fan surge
  • Incorrect direction of rotation. Make sure the fan rotates in same direction as the arrows on the motor or belt drive assembly
Low Capacity or Pressure
  • Poor fan inlet conditions - there should be a straight clear duct at the inlet
  • Incorrect direction of rotation - make sure the fan rotates in same direction as the arrows on the motor or belt drive assembly
  • Improper wheel alignment
Overheated Motor
  • Motor improperly wired
  • Cooling air diverted or blocked
  • Improper inlet clearance
  • Incorrect fan RPM
  • Incorrect voltage
Overheated Bearings
  • Improper bearing lubrication
  • Excessive belt tension
  • Ventilation Systems
  • The Engineering ToolBox (2003). Fans - Troubleshooting. [online] Available at: https://www.engineeringtoolbox.com/fan-problems-d_243.html [Accessed Day Month Year].
