Air Change Rate
Calculate air change rates - equations in imperial and SI units.
air change rate
Air Change Rate - Imperial Units
Air change rate - air changes per hour - expressed in imperial Units
n = 60 q / V                                  (1)
n = air changes per hour (1/h)
q = fresh air (make up air) flow through the room (Cubic Feet per Minute,  cfm)
V = volume of the room (Cubic Feet)
Air Change Rate - SI Units
Air change rate expressed in SI-units
n = 3600 q / V                             (2)
q = fresh air (make up air) flow through the room (m3/s)
V = volume of the room (m3)
Example - Air Change Rate SI Units
With an air flow of 3 m3/s in a 20000 m3 room the air change rate can be calculated as
n = 3600 (3 m3/s) / (20000 m3)
= 0.54 (h-1)
Typical Air Changes per Hour
Typical air changes per hour for well-insulated spaces:
  • no windows or exterior doors - 0.33 (1/h)
  • windows or exterior doors on one side - 0.67 (1/h)
  • windows or exterior doors on two sides - 1 (1/h)
  • window or exterior doors on three sides - 1.33 (1/h)
  • Ventilation Systems
  • The Engineering ToolBox (2005). Air Change Rate. [online] Available at: https://www.engineeringtoolbox.com/air-change-rate-d_882.html [Accessed Day Month Year].
