Concrete - Water to Cement Ratios
Water vs. cement ratio when mixing concrete.
water cement mix
Water to cement ratio is the ratio of
weight of water to the weight of cement
used in a concrete mix and can be expressed as
r = wh20 / wc
  = 8.33 qH20 / wc                             (1)
r = water to cement ratio
wh20 = weight of water (lbs)
w= weight of cement (lbs)
qH20 = volume of water (US gallon)
Example - Water to Cement Ratio
A batch of concrete has 45 gallons of water and 900 lbs of cement. The water to cement ratio can be calculated as
r = 8.33 (45 gallons) / (900 lbs)
  = 0.42
  • The Engineering ToolBox (2010). Concrete - Water to Cement Ratios. [online] Available at: https://www.engineeringtoolbox.com/water-cement-ratio-d_1711.html [Accessed Day Month Year].
