Pythagorean Theorem
Verifying square corners.
Triangle - the Pythagorean theorem
The Pythagorean theorem often used
  • to verify if a corner is square (90 degrees)
and can be expressed as
C2 = A2 + B2                         (1)
(1) can be transformed to express the length of hypotenuse C as
C = (A2 + B2)1/2                                     (1b)
Example - Determine the length of the Hypotenuse  - C
With A = 5 m and B = 10 m - the length of the hypotenuse - C - can be calculated as
C = ((5 m)2 + (10 m)2)1/2
   = 11.2 m
Squaring a Corner
Pythagorean theorem - squaring corners
The angle is square (90 degrees) if
  • A = 3 (m, ft)
  • B = 4 (m, ft)
  • C = 5 (m, ft)
Hypotenuse Calculator
Calculate square triangle hypotenuse - C - length:
The Sine Rule
A / sin a = B / sin b = C / sin c                          (2)
  • Mathematics
  • The Engineering ToolBox (2010). Pythagorean Theorem. [online] Available at: https://www.engineeringtoolbox.com/pythagorean-theorem-d_1713.html [Accessed Day Month Year].
