Heat Index vs. Humidity
The influence of humidity on the apparent temperature and the heat index.
The Heat Index - or the Apparent Temperature - is used to indicate how hot it feels when relative humidity is combined with temperature.
With increased humidity it feels hotter as indicated in the Heat Index table bellow:
Heat Index
Dry Temperature
Relative Humidity (%)
(oF)(oC)0102030405060708090100
70 21.1 64 65 66 67 68 69 70 70 71 71 72
75 23.9 69 70 72 73 74 75 76 77 78 79 80
80 26.7 73 75 77 78 79 81 82 85 86 88 91
85 29.4 78 80 82 84 86 88 90 93 97 102 108
90 32.2 83 85 87 90 93 96 100 106 113 122
95 35 87 90 93 96 101 107 114 124 136
100 37.8 91 95 99 104 110 120 132 144
105 40.6 95 100 105 113 123 135 149
110 43.3 99 105 112 123 137 150
115 46.1 103 111 120 135 151
120 48.9 107 116 130 148
Heat and Humidity Index Danger Zones
  • 90 - 104 : Heat cramps or heat exhaustion possible
  • 105 - 130 : Heat cramps or heat exhaustion likely, heatstroke possible
  • 130 and more : Heat stroke highly likely
Example - Apparent Temperature
From the table - with dry temperature 85 oF and relative humidity 80% - the apparent temperature - or Heat Index - is 97 oF.
heat and humidity index danger zones
  • Air Psychrometrics
  • The Engineering ToolBox (2009). Heat Index vs. Humidity. [online] Available at: https://www.engineeringtoolbox.com/heat-humidity-factor-d_1505.html [Accessed Day Month Year].
