Energy Transfer Equation
Fluid energy transfer.
The energy transfered with a substance can be expressed as
Q = m cp dt                                   (1)
Q = quantity of energy transferred (kJ, Btu)
m = mass of substance (kg, lb)
cp = specific heat of the substance (kJ/kgoC, kJ/kgoK, Btu/lboF)
dt = temperature difference (rise or fall) in the substance (oC, K, oF)
Example - Energy Transfer with Water
2 kg of water is heated from 20 oC to 60 oC. The specific heat of water is 4.2 kJ/kgoC. The heat transfered can be calculated as
Q = (2 kg) (4.2 kJ/kgoC) ((60 oC) - (20 oC))
= 336 kJ
         = (336 kWs) (1/3600 h/s)
         = 0.093 kWh
