Cavitation Number
An introduction and definition of the Cavitation Number.
The Cavitation Number or Cavitation Parameter is a "special edition" of the dimensionless Euler Number.
The Cavitation Number is useful when analyzing fluid flow dynamics problems where cavitation may occur.
The Cavitation Number can be expressed as
σ = (pr - pv) / (1/2 ρ v2)                              (1)
σ = Cavitation number
pr = reference pressure (Pa)
pv = vapor pressure of the fluid (Pa)
ρ = density of the fluid (kg/m3)
v = velocity of fluid (m/s)
To prevent cavitation
  • avoid low pressure - pressurize supply tanks if necessary
  • reduce fluid temperature
  • use larger suction pipe diameters - reduce minor losses
  • use cavitation resistant materials or coatings
  • small amounts of air supplied to the suction system may reduce the amount of cavitation damage
  • keep available NPSH well above required NPSH.
  • Cavitation
    Cavitation occurs in fluid flow systems where the local static pressures are below the fluids vapor pressure.
  • Control Valves - Cavitation
    Control valves and cavitation, application ratio and multi stage control valves.
  • Euler Number
    Introduction to the Euler Number used in fluid mechanics.
  • The Engineering ToolBox (2004). Cavitation Number. [online] Available at: https://www.engineeringtoolbox.com/cavitation-number-d_584.html [Accessed Day Month Year].
