Archimedes' Law
Forces acting on bodies submerged in fluids.
Archimedes buoyant force
Archimedes' principle states that:
"If a solid body floats or is submerged in a liquid - the liquid exerts an upward thrust force - a buoyant force - on the body equal to the gravitational force on the liquid displaced by the body."
The buoyant force can be expressed as
F B =  W
= V γ
= V ρ g                                     (1)
F B = buoyant force acting on submerged or floating body (N, lbf )
W = weight (gravity force) of displaced liquid (N, lbf )
V = volume of body below surface of liquid (m3, ft3 )
γ = ρ g = specific weight of fluid (weight per unit volume) (N/m3, lbf /ft3 )
ρ = density of fluid (kg/m3, slugs/ft3 )
g = acceleration of gravity (9.81 m/s2, 32.174 ft/s2)
Example - Density of a Body that floats in Water
A floating body is 95% submerged in water with density 1000 kg/m 3.
For a floating body the buoyant force is equal to the weight of the water displaced by the body.
F B =  W
or
V b ρ b g = V w ρ w g
V b = volume body (m3 )
ρ b = density of body ( kg/m3 )
V w = volume of water (m3 )
ρ w = density of water ( kg/m3 )
The equation can be transformed to
ρ b = V w ρ w / V b
Since 95% of the body is submerged
0.95 V b = V w
and the density of the body can be calculated as
ρ b = 0.95 V b (1000 kg/m3 ) / V b
= 950 kg/m3
Example - Buoyant force acting on a Brick submerged in Water
A standard brick with actual size 3 5/8 x 2 1/4 x 8 (inches) is submerged in water with density 1.940 slugs /ft3 . The volume of the brick can be calculated
V brick = (3 5/8 in) (2 1/4 in) (8 in)
= 65.25 in3
The buoyant force acting on the brick is equal to the weight of the water displaced by the brick and can be calculated as
F B =  (( 65.25 in3 ) / (1728 in/ft3 )) ( 1.940 slugs/ft3 ) ( 32.174 ft/s2)
= 2.36 lbf
The weight or the gravity force acting on the brick - common red brick has specific gravity 1.75 - can be calculated to
W B = (2.36 lbf ) 1.75
= 4.12 lbf
The resulting force acting on the brick can be calculated as
W (WB - FB) = (4.12 lbf ) - (2.36 lbf )
= 1.76 lbf
  • The Engineering ToolBox (2012). Archimedes' Law. [online] Available at: https://www.engineeringtoolbox.com/archimedes-principle-d_1845.html [Accessed Day Month Year].
