A major friction loss diagram for air ducts - SI units.
Friction loss in standard air ducts:
air ducts - pressure loss vs- air flow chart - m3/s. m/s, mmDownload and print Air Duct Pressure Loss vs. Air Flow and Duct Dimension Chart
  • 1 m/s = 196.85 ft/min
  • 1 m3/s = 3600 m3/h = 1000 dm3(liter)/s = 35.32 ft3/s = 2118.9 ft3/min = 13200 Imp.gal (UK)/min = 15852 gal (US)/min
  • 1 mm H2O = 9.81 Pa = 9.807x10-6 N/mm2 = 0.0987 10-3 bar = 1 kp/m2 = 0.09678 10-3 atm = 1.422 10-3 psi (lbf/in2)
Example - Air Duct and Friction Loss
As indicated in the diagram above, the friction loss in a 500 mm main duct with air flow 1 m3/s  - in a comfort system with air velocity limited to 5 m/s - can be estimated to 0.55 Pa/m (0.055 mm H2O/m).
  • Ventilation Systems
  • The Engineering ToolBox (2008). Air Ducts - Friction Loss Diagram. [online] Available at: https://www.engineeringtoolbox.com/air-duct-friction-loss-diagram-d_328.html [Accessed Day Month Year].
