Surface Tension - Water in contact with Air
Surface tension of water in contact with air for temperatures ranging 0 to 100 degC (32 to 212 degF) - in imperial units (BG units) and SI units.
Surface Tension of Water in Contact with Air - Imperial units (BG units)
Surface Tension - Water in contact with Air - Imperial Units
Temperature
- t -
(oF)
Surface Tension of Water in contact with Air
- σ -
(10-3 lb/ft)
32 5.18
40 5.13
50 5.09
60 5.03
70 4.97
80 4.91
90 4.86
100 4.79
120 4.67
140 4.53
160 4.40
180 4.26
200 4.12
212 4.04
Surface Tension of Water in Contact with Air - SI units
Surface Tension - Water in contact with Air - SI Units
Temperature
- t -
(oC)
- σ -
(10-2 N/m)
0 7.56
5 7.49
10 7.42
20 7.28
30 7.12
40 6.96
50 6.79
60 6.62
70 6.44
80 6.26
90 6.08
100 5.89
150 4.82
200 3.76
250 2.64
300 1.47
350 0.37
374.1 0.0
Surface tension water air
  • Capillarity
    Capillarity - or capillary action - is the ability of a narrow tube to draw a liquid upwards against the force of gravity.
  • Surface Tension
    Surface tension of liquids like water, mercury, oils and more.
  • Surface Tension - Water in contact with Air
  • Weber Number
    The Weber Number may be useful when analyzing fluid flows where there is an interface between two different fluids.
  • The Engineering ToolBox (2004). Surface Tension - Water in contact with Air. [online] Available at: https://www.engineeringtoolbox.com/water-surface-tension-d_597.html [Accessed Day Month Year].
