Pumping Water - Energy Cost Calculator
Calculate the energy cost of pumping water.
The energy cost per hour for pumping water can be calculated in imperial units as
C = 0.746 Q h c / (3960 μp μm)                                      (1)
C = cost per hour (USD/hour, EUR/hour, ...)
Q = volume flow (US gpm)
h = differential head (ft)
c = cost rate per kWh (USD/kWh, EUR/kWh, ....)
μp = pump efficiency (0 - 1)
μm= motor efficiency (0 - 1)
Alternative calculation in metric units
C = q ρ g h c / (3.6 106 μp μm)
    =   q p c / (3.6 106 μp μm)                   (2)
q = volume flow (m3/h)
ρ = density (1000 kg/m3)
h = differential head, height (m)
Example - Pumping Energy Cost
10 US gpm is lifted 10 ft. The electricity cost is 0.1 USD/kWh and the pump and motor efficiency 90% (0.9). The cost per hour can be calculated as
C = 0.746 (10 US gpm) (10 ft) (0.1 USD/kWh) / (3960 0.9 0.9)
  = 0.002 USD/hour
Pumping Energy Cost Calculator
Imperial Units:
Metric Units:
    • 1 US gpm = 0.227 m3/h
    • 1 ft = 0.305 m
  • Pumps
  • The Engineering ToolBox (2009). Pumping Water - Energy Cost Calculator. [online] Available at: https://www.engineeringtoolbox.com/water-pumping-costs-d_1527.html [Accessed Day Month Year].
