Velocity-Area Flowmetering
Flow rate or discharge in an open conduit, channel or river can be calculated with the velocity-area principle.
The velocity-area principle is based on velocity measurements in a open flow like a conduit, channel or river.
Conduit, channel or river - Vleocity-area flow rate (discharge) measurement principle
Velocities and depths across the stream are measured as indicated in the figure above. A partial discharge in a section of the stream can be calculated as
qn = vn an              (1)
qn = flow rate or discharge in section n    (m3/s, ft3/s)
vn = measured velocity in section n   (m/s, ft/s)
an = area of section n   (m2, ft2
One simple way to express the section area is
an = dn (ln+1 - ln-1) / 2                              (2)
The total flow in the stream can be summarized to
Q = Σ1n vn an                         (3)
Q = summarized flow rate or discharge in the conduit   (m3/s, ft3/s)
The accuracy of estimate depends on the profile of the conduit and the number of measurements. For conduits with regular shapes like rectangular channels a limited number of measurements are required. For irregular shapes - like natural rivers or similar - higher accuracy requires more measurements both horizontal and vertical.
Example - Computing Flow Rate in a Channel
From a conduit we have three measurements:
Measured ValuesCalculated Values
nv
(m/s)
d
(m)
l
(m)
a
(m2)
q
(m3/s)
0 0 0 0
1 3 1 2 2 6
2 4 1.5 4 3 12
3 3 0.9 6 1.8 5.4
4 0 0 8
Summarized 23.4
The section areas can be calculated like
a1 = (1 m) ((4 m) - (0 m)) / 2
     = 2 m2
a2 = (1.5 m) ((6 m) - (2 m)) / 2
     = 3 m2
a3 = (0.9 m) ((8 m) - (4 m)) / 2
     = 1.8 m2
The flow rates can be calculated as
q1 = (3 m/s) (2 m2)
    = 6 m3/s
q2 = (4 m/s) (3 m2)
    = 12 m3/s
q3 = (3 m/s) (1.8 m2)
    = 5.4 m3/s
The total flow can be summarized as
Q = (6 m3/s) + (12 m3/s) + (5.4 m3/s)
   = 23.4 m3/s
Note - there are alternative ways to calculate the section flow rates:
Simple Average Method
Using the simple average of two successive vertical depths, their mean velocity, and the distance between them can be expressed as
qn to n+1  = [(vn + vn+1) / 2] [(dn + dn+1 ) / 2] (ln+1 - ln)                  (4)
Midsection Method
With the midsection method, the depth and mean velocity are measured for each number of verticals along the cross section. The depth at a vertical is multiplied by the width, which extends halfway to the preceding vertical and halfway to the following vertical, to develop a cross-sectional area. The section flow rate can be expressed as
qn = vn [((ln - ln-1) + (ln+1 - ln)) / 2] dn                 (5)
  • Flow Measurements
  • The Engineering ToolBox (2017). Velocity-Area Flowmetering. [online] Available at: https://www.engineeringtoolbox.com/velocity-area-computing-flow-principle-d_1974.html [Accessed Day Month Year].
