Vacuum - Flow Measurement
Measure air volume flow in vacuum.
For standard or normal pressure it is common to measure flow in
  • standard cubic feet minute - scfm - imperial units
  • normal metric liter per second - nl/s - metric units
In vacuum the air or gas is expanded and it is common to use
  • actual cubic feet minute - acfm - imperial units
  • actual metric liter per second - al/s - metric units
Since the gas is expanded, actual volume flow is greater than standard volume flow for the same amount of gas.
The flow volume can be converted from standard volume flow to actual volume flow by the expression:
qa = qs (29.92 / p) ((t + 460) / 520)                                  (1)
qa= actual volume flow (acfm)
qs= standard volume flow (scfm)
p= actual pressure (in Hg)
t= temperature (oF)
Vacuum - Flow Measurement Conversion Factor
PressureConversion Factor from scfm to acfm (or nl/s to al/s)
Temperature(oF)
in Hg absolutein Hg gaugekPa absolute0306090120150
29.92 0.00 101.42 0.88 0.94 1.00 1.06 1.12 1.17
28.92 1.00 98.03 0.92 0.97 1.03 1.09 1.15 1.21
27.92 2.00 94.64 0.95 1.01 1.07 1.13 1.20 1.26
26.92 3.00 91.25 0.98 1.05 1.11 1.18 1.24 1.30
25.92 4.00 87.86 1.02 1.09 1.15 1.22 1.29 1.35
24.92 5.00 84.47 1.06 1.13 1.20 1.27 1.34 1.41
23.92 6.00 81.08 1.11 1.18 1.25 1.32 1.40 1.47
22.92 7.00 77.69 1.15 1.23 1.31 1.38 1.46 1.53
21.92 8.00 74.31 1.21 1.29 1.36 1.44 1.52 1.60
20.92 9.00 70.92 1.27 1.35 1.43 1.51 1.60 1.68
19.92 10.00 67.53 1.33 1.42 1.50 1.59 1.68 1.76
18.92 11.00 64.14 1.40 1.49 1.58 1.67 1.76 1.86
17.92 12.00 60.75 1.48 1.57 1.67 1.77 1.86 1.96
16.92 13.00 57.36 1.56 1.67 1.77 1.87 1.97 2.07
15.92 14.00 53.97 1.66 1.77 1.88 1.99 2.10 2.20
14.92 15.00 50.58 1.77 1.89 2.01 2.12 2.24 2.35
13.92 16.00 47.19 1.90 2.03 2.15 2.27 2.40 2.52
12.92 17.00 43.80 2.05 2.18 2.32 2.45 2.58 2.72
11.92 18.00 40.41 2.22 2.37 2.51 2.65 2.80 2.94
10.92 19.00 37.02 2.42 2.58 2.74 2.90 3.06 3.21
9.92 20.00 33.63 2.67 2.84 3.02 3.19 3.36 3.54
8.92 21.00 30.24 2.97 3.16 3.35 3.55 3.74 3.93
7.92 22.00 26.85 3.34 3.56 3.78 4.00 4.21 4.43
6.92 23.00 23.46 3.82 4.07 4.32 4.57 4.82 5.07
5.92 24.00 20.07 4.47 4.76 5.05 5.35 5.64 5.93
4.92 25.00 16.68 5.38 5.73 6.08 6.43 6.78 7.13
3.92 26.00 13.29 6.75 7.19 7.63 8.07 8.51 8.95
2.92 27.00 9.90 9.06 9.66 10.25 10.84 11.43 12.02
1.92 28.00 6.51 13.79 14.68 15.58 16.48 17.38 18.28
0.92 29.00 3.12 28.77 30.65 32.52 34.40 36.27 38.15
0.82 29.10 2.78 32.28 34.38 36.49 38.59 40.70 42.80
0.72 29.20 2.44 36.76 39.16 41.56 43.95 46.35 48.75
0.62 29.30 2.10 42.69 45.47 48.26 51.04 53.83 56.61
0.52 29.40 1.76 50.90 54.22 57.54 60.86 64.18 67.50
0.42 29.50 1.42 63.02 67.13 71.24 75.35 79.46 83.57
0.32 29.60 1.08 82.71 88.11 93.50 98.89 104.29 109.68
0.22 29.70 0.75 120.31 128.15 136.00 143.85 151.69 159.54
0.12 29.80 0.41 220.56 234.95 249.33 263.72 278.10 292.49
  • The Engineering ToolBox (2005). Vacuum - Flow Measurement. [online] Available at: https://www.engineeringtoolbox.com/vacuum-flow-measurement-d_836.html [Accessed Day Month Year].
