Pressure Energy
Calculate the potential of pressure energy in a incompressible fluid.
The pressure energy in an incompressible fluid volume, like a pressurized tank with water, can be expressed as
Δ E = Δp / ρ                                (1)
Δ E = potential energy (J/kg, Btu/lb)
Δ p = pressure difference (Pa (N/m2), lb/ft2)
ρ = density of fluid (kg/m3, lb/ft3 )
Example - Pressure Energy in a Water Tank
The pressure in a water tank is 10 bar (106 Pa) . With density of water 1000 kg/m 3 the potential pressure energy can be calculated as
E = (106 Pa) / ( 1000 kg/m >3 )
= 1000 J/kg
  • The Engineering ToolBox (2012). Pressure Energy. [online] Available at: https://www.engineeringtoolbox.com/pressure-energy-d_1822.html [Accessed Day Month Year].
