Domestic Hot Water Heaters - Sizing
Domestic Hot-Water sizing equations - heating capacity, recovery rate and power supply.
Domestic hot-water systems supplies taps in houses or buildings with hot water.
Output Heating Capacity
Output heating capacity of a domestic hot-water system:
hout = q ρ dt cp                                (1)
hout = heating capacity, output (Btu/h)
q = flow rate (gph)
ρ = 8.34 - density of water (lbs/gal)
dt = temperature rise (oF)
cp = 1.0 - specific heat of water (Btu/lboF)
Input Heating Capacity
Input heating capacity of a domestic hot-water system:
hin = q ρ dt cp / μ                             (2)
hin = heating capacity, input (Btu/h)
μ = efficiency
Recovery Rate
Recovery rate for an electrical heater in a domestic hot water system:
RR = hin μ / (dt ρ)
    = P (3413 Btu/kW) / (dt ρ)                              (3)
RR = recovery rate (gal/h)
P = electrical power supplied by heater (kW)
Temperature Rise
Temperature rise in an electrical heater in a domestic hot-water system:
dt = hin μ / (q ρ)
    = P (3413 Btu/kW) / qρ                                (4)
Electrical Power Supply
Electrical power supply to a domestic hot-water systems:
P = q ρ dt cp / (3413 Btu/kW)                                (5)
