Ductwork - Supports
Recommended distance between ductwork support hangers.
The support distance for ductwork is typical based upon deflection, stress and cylinder buckling analysis.
duct supports
For sheet metal duct work the space between the hangers should not exceed the distances listed below:
Horizontal Ductwork
Ductwork - Support Spacing
Ducts SizeMaximum Spacing
(ft, m)
Area
(ft2, m2)
Diameter
(in, mm)
less than 4 (0.4) less than 5 (125) 8 (2.5)
(0.4) to 10 (1) 5 (125) to 38 (1000) 6 (2)
more than 10 (1) more than 38 (1000) 4 (1.2)
Vertical Ductwork
Ducts TypeMaximum Spacing
(ft, m)
round 12 (3.6)
rectangular 10 (3)
  • 1 ft2 = 0.0929 m2 = 144 in2
  • 1 ft (foot) = 0.3048 m = 12 in
Note! Support systems for ductwork may provide restraint in three directions against displacement and rotation. Consideration must be given with restraining ducts to avoid development of excessive internal duct stresses caused by expansion or contraction due to temperature variations.
  • Ventilation Systems
  • The Engineering ToolBox (2005). Ductwork - Supports. [online] Available at: https://www.engineeringtoolbox.com/ductwork-spacing-d_927.html [Accessed Day Month Year].
