Drain Waste and Vent Pipes - Hanger Spacing
Support of Drain Waste and Vent - DWV - pipes.
Both vertical and horizontal drainage pipes must be supported properly. Recommended maximum distances between the hangers are indicated in the table below.
Piping MaterialDistance between Supports (ft)
Horizontal PipeVertical Pipe
ABS plastic 4 4
Galvanized steel 12 15
DWV Copper 10 10
Cast Iron 5 151)
PVC plastic 4 4
1) For cast iron stacks, the base of each stack must be supported
  • Sanitary Drainage Systems
    The purpose of the sanitary drainage system is to remove effluent discharged from plumbing fixtures and other equipment.
  • The Engineering ToolBox (2008). Drain Waste and Vent Pipes - Hanger Spacing. [online] Available at: https://www.engineeringtoolbox.com/drainage-pipe-supports-d_1106.html [Accessed Day Month Year].
