Dalton's Law
Gibbs' Dalton's law of the total pressure of a mixture of gases.
The total pressure of a mixture of gases is made up by the sum of the partial pressures of the components in the mixture - also known from Gibbs'-Dalton's Law of Partial Pressures.
  • the total pressure exerted by a mixture of gases is the sum of the partial pressures of the individual gases
The total pressure in a mixture of gases can be expressed as:
p total = p1 + p2+ .. + p n
= Σp i (1)
p total = total pressure of mixture    (Pa, psi)
p i = partial pressure of individual gas   (Pa, psi)
Assuming that each gas behaves ideally - the partial pressure for each gas can calculated from the Ideal gas Law as
p i = n1 R T / V                     (2)
p i = pressure (Pa, psi)
n1 = the number of moles of the gas
R = universal gas constant (J/(mol K), lbf ft/(lb mol o R),  8.3145 (J/(mol K))
T = absolute temperature (K, o R)
V = volume (m3, ft3 )
Example - Partial Pressure of single Gas
If there is 2 moles of gas in 0.005 m3 volume ( 5 litre ) with temperature 27°C ( 300 K ) - the partial pressure of the gas can be calculated as
p i = (2) ( 8.3145 J/(mol K) ) (300 K) / (0.005 m3 )
= 997740 Pa
= 997 kPa
  • The Engineering ToolBox (2008). Dalton's Law. [online] Available at: https://www.engineeringtoolbox.com/daltons-law-d_1052.html [Accessed Day Month Year].
