Carbon and Stainless Steel Flanges - ASME/ANSI Class 300
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 300 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts.
ASME/ANSI B16.5-1996 Pipe Flanges and Flanged Fittings - Class 300 Flanges - outside and inside diameters, bolt circles, numbers and diameters of bolts for Weld neck, Threaded, Slip-on, Lap joint, Socket weld and Blind flanges.
Carbon and stainless steel qualities according ASME B16.5 Table 1A.
Pipe Size
(inches)
Flange Outside Diameter
(inches)
Pipe Outside Diameter
(inches)
Number of Bolt HolesBolt Hole Diameter
(inches) 1)
Bolt Circle
(inches)
1/2 3-3/4 0.84 4 5/8 2-5/8
3/4 4-5/8 1.05 4 3/4 3-1/4
1 4-7/8 1.32 4 3/4 3-1/2
1-1/4 5-1/4 1.66 4 3/4 3-7/8
1-1/2 6-1/8 1.90 4 7/8 4-1/2
2 6-1/2 2.38 8 3/4 5
2-1/2 7-1/2 2.88 8 7/8 5-7/8
3 8-1/4 3.50 8 7/8 6-5/8
3-1/2 9 4.00 8 7/8 7-1/4
4 10 4.50 8 7/8 7-7/8
5 11 5.56 8 7/8 9-1/4
6 12-1/2 6.63 12 7/8 10-5/8
8 15 8.63 12 1 13
10 17-1/2 10.75 16 1-1/8 15-1/4
12 20-1/2 12.75 16 1-1/4 17-3/4
14 23 14.00 20 1-1/4 20-1/4
16 25-1/2 16.00 20 1-3/8 22-1/2
18 28 18.00 24 1-3/8 24-3/4
20 30-1/2 20.00 24 1-3/8 27
24 36 24.00 24 1-5/8 32
1) Recommended bolts are 1/8 smaller than the nominal bolt hole diameters shown.
  • 1 inch = 25.4 mm
Engineering ToolBox Sketchup Extension - Flanges
  • Piping Systems
  • The Engineering ToolBox (2003). Carbon and Stainless Steel Flanges - ASME/ANSI Class 300. [online] Available at: https://www.engineeringtoolbox.com/asme-carbon-stainless-steel-flanges-d_302.html [Accessed Day Month Year].
