Zeroth Law of Temperature
The direction of heat flow.
The Zeroth law of Temperature states that
"Heat flows from one source to an other only if there is a temperature difference between the two.
Two systems are in thermal equilibrium if they are at same temperature."
The law is important for the mathematical formulation of thermodynamics where the relation of thermal equilibrium is the basis for an equivalence relation.
