NEMA and IEC Enclosure Classifications
NEMA enclosure classifications versus IEC enclosure classifications.
NEMA enclosure classifications are developed by NEMA and used in the U.S./American market.
Ingress Protection - IP - ratings are developed by the European Committee for Electro Technical Standardization (CENELEC) (described IEC/EN 60529), and specifies the environmental protection and enclosure provided.
The table below can be used to convert from NEMA Enclosure Types to IEC Enclosure Types:
NEMA Enclosure TypesIEC Enclosure Classification Designation
1 General Purpose - Indoor IP10 Protected against solid objects up to 50mm, e.g. accidental touch by hands.
2 Drip-Proof - Indoor IP11 Protected against solid objects up to 50mm, e.g. accidental touch by hands.
Protection against vertically falling drops of water e.g. condensation.
3 Dust-tight, Rain-tight, Sleet-tight - Outdoor IP54 Protected against dust limited ingress (no harmful deposit).
Protection against water sprayed from all directions, limited ingress permitted.
3R Rain-tight, Sleet Resistant- Outdoor IP14 Protected against solid objects up to 50mm, e.g. accidental touch by hands.
3S Dust-tight, Rain-tight, Sleet-tight- Outdoor IP54 Protected against dust limited ingress (no harmful deposit).
4 Water-tight, Dust-tight, Sleet Resistant-Indoor & Outdoor IP56 Protected against dust limited ingress (no harmful deposit).
4X Water-tight, Dust-tight, Corrosion-Resistant- Indoor & Outdoor IP56 Protected against dust limited ingress (no harmful deposit).
5 Dust-tight, Drip-Proof--Indoor IP52 Protected against dust limited ingress (no harmful deposit).
Protection against direct sprays of water up to 15o from the vertical.
6 Occasionally Submersible, Watertight, Sleet Resistant- Indoor & Outdoor IP67 Totally protected against dust.
Protected against the effect of immersion between 15cm and 1m.
6P Water-tight, Sleet Resistant- Prolonged Submersion- Indoor & Outdoor IP67 Totally protected against dust.
12 Dust-tight and Drip-tight- Indoor IP52 Protected against dust limited ingress (no harmful deposit).
12K Dust-tight and Drip-tight, with Knockouts- Indoor IP52 Protected against dust limited ingress (no harmful deposit).
13 Oil-tight and Dust-tight- Indoor IP54 Protected against dust limited ingress (no harmful deposit).
Note! NEMA standards meets or exceeds IEC standards. The conversion does not work in the opposite direction.
  • Electrical
  • The Engineering ToolBox (2005). NEMA and IEC Enclosure Classifications. [online] Available at: https://www.engineeringtoolbox.com/nema-iec-enclosure-standards-d_920.html [Accessed Day Month Year].
