Mollier chart for water in English Units.
You can change your privacy settings by clicking the following button: Manage Consent.
Temperature oC K oF
Length m km in ft yards miles naut miles
Area m2 km2 in2 ft2 miles2 acres
Volume m3 liters in3 ft3 us gal
Weight kgf N lbf
Velocity m/s km/h ft/min ft/s mph knots
Pressure Pa bar mm H2O kg/cm2 psi inches H2O
Flow m3/s m3/h US gpm cfm
Make Shortcut to Home Screen?
