Laminar Flow - Friction Coefficients
Calculate friction coefficients for laminar fluid flow.
The friction coefficient - or factor - of a fluid flow at laminar conditions can be calculated as
λ = 64 / Re
= 64 μ / (d hu ρ)
= 64 ν / (d hu)                          (1)
λ = friction coefficient (non-dimensional)
Re = Reynolds Number (non-dimensional)
μ = absolute (dynamic) viscosity (Ns/m2, lb m/s ft)
d h= hydraulic diameter (mm, ft)
u = mean velocity in flow (m/s, ft/s)
ρ = density of fluid (kg/m3, lb m/ft3 )
ν = μ / ρ = kinematic viscosity (m2/s, ft2/s)
Equation (1) is only valid at laminar conditions where Reynolds Number is less than 2300 . For turbulent conditions where Reynolds Number exceeds 4000 the Colebrook equation should be used to calculate the friction coefficient.
In practice laminar flow is only actual for viscous fluids - like crude oil, fuel oil and other oils.
The friction coefficient for laminar flow indicated in the Moody diagram (SI based):
moody diagram
  • The Engineering ToolBox (2008). Laminar Flow - Friction Coefficients. [online] Available at: https://www.engineeringtoolbox.com/laminar-friction-coefficient-d_1032.html [Accessed Day Month Year].
