Effective Interest Rate vs. Nominal Interest Rate
Effective interest rate vs. nominal interest rate in sub-periods.
An interest rate is only meaningful in the context of time - in general is understood as - per year - which may be called
  • the nominal interest rate
With other periods of time than the year - like month, week, or day - the interest rate may be called
  • the effective interest rate
Calculating Nominal Interest Rate
Nominal interest rate for a period with effective interest rates in it's sub-periods can be calculated as
i = (1 + ie)n - 1            (1)
i = nominal interest rate for the period
ie = effective interest rate for the sub-period
n = number of sub-periods
Example - Nominal interest rate with Effective monthly interest rates
Nominal interest rate (per year) with 12 monthly effective rates of 1% (ie = 0.01) can be calculated as
in = (1 + 0.01)12 - 1
    =  0.127
    = 12.7%
Calculating Effective Interest Rate
Effective interest rate for sub-periods of a period can be calculated as
ie = (in + 1)1/n - 1        (2)
The effective interest rate per month with a nominal rate of 10% can be calculated as
ie = (0.1 + 1)1/12 - 1
    =  0.00797
    = 0.797%
  • Economics
    Engineering economics - cash flow diagrams, present value, discount rates, internal rates of return - IRR, income taxes, inflation.
  • The Engineering ToolBox (2009). Effective Interest Rate vs. Nominal Interest Rate. [online] Available at: https://www.engineeringtoolbox.com/effective-nominal-interest-rates-d_1468.html [Accessed Day Month Year].
