Change in Duct Area and Noise Attenuation
Sound attenuation vs. change in duct size.
Duct size change - sound attenuation
Sound attenuation when changing duct areas or dimensions:
dL = 10 log( ( 1 + A1 / A2 )2 / 4 (A1 / A2) )        (1)
dL = noise attenuation (dB)
A1 = inlet area (m2)
A2 = outlet area (m2)
Note! - valid only for sharp changes.
Example - Attenuation when changing the size of a duct
The attenuation of noise when the ratio between area before and after A1 / A2 = 5 - can be calculated as
dL = 10 log( ( 1 + 5)2 / 4 (5))
    = 2.5 dB
  • Noise and Attenuation
  • The Engineering ToolBox (2008). Change in Duct Area and Noise Attenuation. [online] Available at: https://www.engineeringtoolbox.com/duct-area-change-noise-attenuation-d_1408.html [Accessed Day Month Year].
