Data Types
Signed vs. unsigned datatypes.
Data Types
Data TypesBitsRange of Values
Unsigned char 8 0 to 255
Signed char 8 -128 to 127
Unsigned short 16 0 to 65535
Signed short 16 -32768 to 32767
Unsigned int 32 0 to 4294967295
Signed int 32 -2147483648 to 2147483647
Float 32 -3.4028 1038 to 3.4028 1038
Double 64 -1.7977 10308 to -1.7977 10308
  • one byte is 8 bits
Example - Unsigned char (byte)
The unsigned char with 8 bits can represent integers from 0 to 255 - check the Binary - to Decimal, Hexadecimal and ASCII Converter
  • The unsigned char (byte) 01100100 represents the decimal number 100.
Example - Signed char (byte)
With the signed char the leading bit indicates the sign of the number. 1 is negative and 0 is positive.
  • The signed char (byte) 01100100 represents the decimal number 100.
  • The signed char (byte) 10011100 represents the decimal number -100.
Example - Unsigned short
  • The unsigned short 00000000 01100100 represents the decimal number 100.
Example - Signed short
  • The signed short 00000000 01100100 represents the decimal number 100.
  • The signed short 11111111 10011100 represents the decimal number -100.
Example - Unsigned int
  • The unsigned int 00000000 00000000 00000000 01100100 represents the decimal number 100.
Example - Signed int
  • The signed int 00000000 00000000 00000000 01100100 represents the decimal number 100.
  • The signed int 11111111 11111111 11111111 10011100 represents the decimal number -100.
Example - Float
  • The Float 01000010 11001000 00000000 00000000 represents the decimal number 100.
  • The Float 11000010 11001000 00000000 00000000 represents the decimal number -100.
Example - Double
  • The Double 01000000 01011001 00000000 00000000 00000000 00000000 00000000 00000000 represents the decimal number 100.
  • The Double 11000000 01011001 00000000 00000000 00000000 00000000 00000000 00000000 represents the decimal number -100.
  • Mathematics
  • The Engineering ToolBox (2016). Data Types. [online] Available at: https://www.engineeringtoolbox.com/data-types-d_1925.html [Accessed Day Month Year].
