Cast Iron
The four basic types of cast iron - white iron, gray iron, ductile iron and malleable iron.
There are four basic types of cast iron
  • white iron
  • gray iron
  • ductile iron
  • malleable iron
White Cast Iron
Characterized by the prevalence of carbides, impacting
  • high compressive strength
  • hardness
  • good resistance to wear
Gray Cast Iron
Characterized with graphite in the microstructure, giving
  • good machinability
  • good resistance to wear and galling
Ductile Cast Iron
Gray iron with small amounts of magnesium and cesium which nodulates the graphite,  resulting
  • high strength
  • high ductility
Malleable Cast Iron
White cast iron heat-treated to improve
  • higher ductility
  • Piping Codes and Standards
  • Piping Systems
  • The Engineering ToolBox (2007). Cast Iron. [online] Available at: https://www.engineeringtoolbox.com/cast-iron-d_1163.html [Accessed Day Month Year].
