Thermal conductivity is a material property that describes ability to conduct heat . Thermal conductivity can be defined as
" the quantity of heat transmitted through a unit thickness of a material - in a direction normal to a surface of unit area - due to a unit temperature gradient under steady state conditions".
Thermal conductivity most common units are W/(m K) in the SI system and Btu/(h ft °F) in the Imperial system.
Tabulated values and thermal conductivity units conversion are given below the figures.
Online Air Thermal Conductivity Calculator
The calculator below can be used to calculate the air thermal conductivity at given temperatures and pressure.
The output conductivity is given as mW/(m K), Btu(IT)/(h ft °F) and kcal(IT)/(h m K).
See also other properties of Air at varying temperature and pressure: Density and specific weight at varying temperature , Density at varying pressure , Diffusion Coefficients for Gases in Air , Prandtl Number , Specific heat at varying temperature and Specific heat at varying pressure , Thermal Diffusivity , Properties at gas-liquid equilibrium conditions and Air thermophysical properties at standard conditions and Composition and molecular weight ,
as well as thermal conductivity o f ammonia , butane , carbon dioxide , ethane , ethylene , hydrogen , methane , nitrogen , propane and water .
See also Conductive Heat Transfer Calculator
Air thermal conductivity at atmospheric pressure and temperatures given in °C:
Temperature | Thermal conductivity | ||
[°C] | [mW/m K] | [kcal(IT)/(h m K)] | [Btu(IT)/(h ft °F)] |
-190 | 7.82 | 0.00672 | 0.00452 |
-150 | 11.69 | 0.01005 | 0.00675 |
-100 | 16.20 | 0.01393 | 0.00936 |
-75 | 18.34 | 0.01577 | 0.01060 |
-50 | 20.41 | 0.01755 | 0.01179 |
-25 | 22.41 | 0.01927 | 0.01295 |
-15 | 23.20 | 0.01995 | 0.01340 |
-10 | 23.59 | 0.02028 | 0.01363 |
-5 | 23.97 | 0.02061 | 0.01385 |
0 | 24.36 | 0.02094 | 0.01407 |
5 | 24.74 | 0.02127 | 0.01429 |
10 | 25.12 | 0.02160 | 0.01451 |
15 | 25.50 | 0.02192 | 0.01473 |
20 | 25.87 | 0.02225 | 0.01495 |
25 | 26.24 | 0.02257 | 0.01516 |
30 | 26.62 | 0.02289 | 0.01538 |
40 | 27.35 | 0.02352 | 0.01580 |
50 | 28.08 | 0.02415 | 0.01623 |
60 | 28.80 | 0.02477 | 0.01664 |
80 | 30.23 | 0.02599 | 0.01746 |
100 | 31.62 | 0.02719 | 0.01827 |
125 | 33.33 | 0.02866 | 0.01926 |
150 | 35.00 | 0.03010 | 0.02022 |
175 | 36.64 | 0.03151 | 0.02117 |
200 | 38.25 | 0.03289 | 0.02210 |
225 | 39.83 | 0.03425 | 0.02301 |
300 | 44.41 | 0.03819 | 0.02566 |
412 | 50.92 | 0.04378 | 0.02942 |
500 | 55.79 | 0.04797 | 0.03224 |
600 | 61.14 | 0.05257 | 0.03533 |
700 | 66.32 | 0.05702 | 0.03832 |
800 | 71.35 | 0.06135 | 0.04122 |
900 | 76.26 | 0.06557 | 0.04406 |
1000 | 81.08 | 0.06971 | 0.04685 |
1100 | 85.83 | 0.07380 | 0.04959 |
Air thermal conductivity at atmospheric pressure and temperatures given in °F:
[°F] | [Btu(IT)/(h ft °F)] | [kcal(IT)/(h m K)] | [mW/m K] |
-300 | 0.00484 | 0.00720 | 8.37 |
-200 | 0.00788 | 0.01172 | 13.63 |
-100 | 0.01068 | 0.01589 | 18.48 |
-50 | 0.01200 | 0.01786 | 20.77 |
-20 | 0.01277 | 0.01901 | 22.10 |
0 | 0.01328 | 0.01976 | 22.98 |
10 | 0.01353 | 0.02013 | 23.41 |
20 | 0.01378 | 0.02050 | 23.84 |
30 | 0.01402 | 0.02087 | 24.27 |
40 | 0.01427 | 0.02123 | 24.70 |
50 | 0.01451 | 0.02160 | 25.12 |
60 | 0.01476 | 0.02196 | 25.54 |
70 | 0.01500 | 0.02232 | 25.95 |
80 | 0.01524 | 0.02267 | 26.37 |
100 | 0.01571 | 0.02338 | 27.19 |
120 | 0.01618 | 0.02408 | 28.00 |
140 | 0.01664 | 0.02477 | 28.80 |
160 | 0.01710 | 0.02545 | 29.60 |
180 | 0.01755 | 0.02612 | 30.38 |
200 | 0.01800 | 0.02679 | 31.16 |
250 | 0.01911 | 0.02843 | 33.07 |
300 | 0.02018 | 0.03003 | 34.93 |
350 | 0.02123 | 0.03160 | 36.75 |
400 | 0.02226 | 0.03313 | 38.53 |
450 | 0.02327 | 0.03463 | 40.28 |
500 | 0.02426 | 0.03611 | 41.99 |
600 | 0.02620 | 0.03898 | 45.34 |
700 | 0.02807 | 0.04177 | 48.58 |
800 | 0.02990 | 0.04449 | 51.74 |
1000 | 0.03342 | 0.04973 | 57.84 |
1200 | 0.03680 | 0.05477 | 63.69 |
1400 | 0.04007 | 0.05963 | 69.35 |
1600 | 0.04325 | 0.06436 | 74.85 |
1800 | 0.04635 | 0.06898 | 80.23 |
2000 | 0.04941 | 0.07353 | 85.51 |
Thermal conductivity units conversion:
british thermal unit(international)/(foot hour degree fahrenheit) [Btu(IT)/(ft h°F], british thermal unit(international)/(inch hour degree fahrenheit) [Btu(IT)/(in h°F], british thermal unit(international)*inch/(square foot*hour*degree fahrenheit) [(Btu(IT) in)/(ft² h°F)], kilocalorie/(meter hour degree celcius) [kcal/(m h°C)], joule/(centimeter second degree kelvin) [J/(cm s K)], watt/(meter degree kelvin) [W/(m°C)],
- 1 Btu(IT)/(ft h°F) = 1/12 Btu(IT)/(in h°F) = 0.08333 Btu(IT)/(in h°F) = 12 Btu(IT)in/(ft2h°F) = 1.488 kcal/(m h°C) = 0.01731 J/(cm s K) = 1.731 W/(m K)
- 1 Btu(IT)/(in h°F) = 12 Btu(IT)/(ft h°F) = 144 Btu(IT)in/(ft2h°F) = 17.858 kcal/(m h°C) = 0.20769 J/(cm s K)= 20.769 W/(m K)
- 1 (Btu(IT) in)/(ft² h°F) = 0.08333 Btu(IT)/(ft h°F) = 0.00694 Btu(IT)/(in h°F) = 0.12401 kcal/(m h°C) = 0.001442 J/(cm s K) = 0.1442 W/(m K)
- 1 J/(cm s K) = 100 W/(m K) = 57.789 Btu(IT)/(ft h°F) = 4.8149 Btu(IT)/(in h°F) = 693.35 (Btu(IT) in)/(ft² h°F) = 85.984 kcal/(m h°C)
- 1 kcal/(m h°C) = 0.6720 Btu(IT)/(ft h°F) = 0.05600 Btu(IT)/(in h°F) = 8.0636 (Btu(IT) in)/(ft2h°F) = 0.01163 J/(cm s K) = 1.163 W/(m K)
- 1 W/(m K) = 0.01 J/(cm s K) = 0.5779 Btu(IT)/(ft h°F) = 0.04815 Btu(IT)/(in h°F) = 6.9335 (Btu(IT) in)/(ft² h°F) = 0.85984 kcal/(m h°C)
Air Psychrometrics
Moist and humid air calculations. Psychrometric charts and Mollier diagrams. Air-condition systems temperatures, absolute and relative humidities and moisture content in air. -
Fluid Mechanics
Gases and Compressed Air
Properties of air, LNG, LPG and other common gases. Pipeline capacities and sizing of relief valves. -
Material Properties
Dry air is a mechanical mixture of nitrogen, oxygen, argon and several other gases in minor amounts. -
Air - Density vs. Pressure and Temperatures
Air density at pressure ranging 1 to 10 000 bara (14.5 - 145000 psi) and constant selected temperatures. -
Online calculator, figures and tables showing density, specific weight and thermal expansion coefficients of air at temperatures ranging -100 to 1600 °C (-140 to 2900 °F) at atmospheric and higher pressure - Imperial and SI Units. -
Diffusion coefficients (D12) for gases in large excess of air at temperatures ranging 0 - 400 °C. -
Air - Dynamic and Kinematic Viscosity
Online calculator, figures and tables with dynamic (absolute) and kinematic viscosity for air at temperatures ranging -100 to 1600°C (-150 to 2900°F) and at pressures ranging 1 to 10 000 bara (14.5 - 145000 psia) - SI and Imperial Units. -
Air - Humidity Ratio
The mass of water vapor present in moist air - to the mass of dry air. -
The moisture holding capacity of air increases with temperature. -
Dry air is a mixture of gases where the average molecular weight (or molar mass) can be calculated by adding the weight of each component. -
Air - Prandtl Number
Prandtl number for air vs. temperature and pressure. -
Air - Specific Heat Ratio
Specific Heat Ratio of air at temperatures ranging -40 - 1000 degC (-40 - 1500 degF) at standard atmospheric pressure - Imperial and SI Units. -
Figures and tables with isobaric (Cp) and isochoric (Cv) specific heat of air at constant temperature and pressure ranging 0.01 to 10000 bara. -
Air - Specific Heat vs. Temperature at Constant Pressure
Online calculator with figures and tables showing specific heat (Cp and Cv) of dry air vs. temperature and pressure. SI and imperial units. -
Air - Speed of Sound vs. Temperature
Speed of sound in air at standard atmospheric pressure with temperatures ranging -40 to 1000 °C (-40 to 1500 °F) - Imperial and SI Units. -
Figures and tables withdry air thermal diffusivity vs. temperarure and pressure. SI and Imperial units. -
Thermal properties of air at different temperatures - density, viscosity, critical temperature and pressure, triple point, enthalpi and entropi, thermal conductivity and diffusivity and more. -
Air Conditioning - Cooling of Air and Condensate Generated
Water may condensate when air is cooled in air conditioning systems. -
Air Properties - SI Units
Ideal gas properties of air at low pressure - SI units. -
Online calculator, figures and tables showing thermal conductivity of liquid and gaseous ammonia at temperatures ranging -70 to 425 °C (-100 to 800 °F) at atmospheric and higher pressure - Imperial and SI Units. -
Online calculators, figures and tables showing thermal conductivity of liquid and gaseous butane, C4H10, at varying temperature and pressure, SI and Imperial units. -
Online calculator, figures and table showing thermal conductivity of carbon dioxide, CO2, at temperatures ranging from -50 to 775 °C (-50 to 1400 °F) at atmospheric and higher pressure - Imperial and SI Units. -
Pressure loss in compressed air pipe lines. -
Dry Air - Thermodynamic and Physical Properties
Thermodynamic properties of dry air - specific heat, ratio of specific heats, dynamic viscosity, thermal conductivity, Prandtl number, density and kinematic viscosity at temperatures ranging 175 - 1900 K. -
Online calculator, figures and table showing thermal conductivity of ethane, C2H6, at varying temperature and pressure - Imperial and SI Units. -
Online calculator, figures and table showing thermal conductivity of ethylene, also called ethene or acetene, C2H4, at varying temperature and pressure - Imperial and SI Units. -
Humid Air - Heating
Enthalpy change and temperature rise when heating humid air without adding moisture. -
Online calculator, figures and table showing thermal conductivity of hydrogen, H2, at varying temperature and pressure - Imperial and SI Units. -
Online calculator, figures and table showing thermal conductivity of methane, CH4, at temperatures ranging from -160 to 725 °C (-260 to 1300 °F) at atmospheric and higher pressure - Imperial and SI Units. -
Moist Air - Properties
Psychrometric table with humid air properties like saturation pressure, specific volume, enthalpy and entropy. -
Moist Air - Specific Volume
Specific volume of moist air is defined as the total volume of humid air per mass unit of dry air -
Moist Air - Weight of Water Vapor
Weight of water vapor in air -
Online calculator, figures and tables showing thermal conductivity of liquid and gaseous propane at varying temperarure and pressure, SI and Imperial units. -
Solubility of Air in Water
The amount of air that can be dissolved in water decreases with temperature and increases with pressure. -
The definition of STP - Standard Temperature and Pressure and NTP - Normal Temperature and Pressure. -
U.S. Standard Atmosphere vs. Altitude
Properties of the US standard atmosphere ranging -5000 to 250000 ft altitude. -
