Hydraulic Force vs. Pascal's Law
Pascal's Laws relates to pressures in incompressible fluids - liquids.
  • if the weight of a fluid is neglected the pressure throughout an enclosed volume will be the same
  • the static pressure in a fluid acts equally in all directions
  • the static pressure acts at right angles to any surface in contact with the fluid
Example - Pressure in a Hydraulic Cylinder
The pressure of 2000 Pa in an hydraulic cylinder acts equally on all surfaces. The force on a piston with area 0.1 m2 can be calculated
F = p A                              (1)
F = force (N)
p = pressure (Pa, N/m2)
A = area (m2)
or with values
F = (2000 Pa) (0.1 m2)
= 200 (N)
Example - Force in a Hydraulic Jack
The pressure acting on both pistons in a hydraulic jack is equal.
The force equation for the small cylinder:
F s = p A s (2)
F s = force acting on the piston in the small cylinder (N)
A s = area of small cylinder (m2)
p = pressure in small and large cylinder  (Pa, N/m2)
The force equation for the large cylinder:
F l = p A l (2b)
F l = force acting on the piston in the large cylinder (N)
A l = area of large cylinder (m2)
(2) and (2b) can be combined to
F s / A s = F l / A l (2c)
or
F s = F l A s / A l (2d)
The equation indicates that the effort force required in the small cylinder to lift a load on the large cylinder depends on the area ratio between the small and the large cylinder - the effort force can be reduced by reducing the small cylinder area compared to the large cylinder area.
A Hydraulic Jack Lifting a Car
The back end (half the weight) of a car of mass 2000 kg is lifted by an hydraulic jack where the A s / A l ratio is 0.1 (the area of the large cylinder is 10 times the area of the small cylinder).
The force - weight - acting on the large cylinder can be calculated with Newton's Second Law:
F l = m a
m = mass (kg)
a = acceleration of gravity (m/s2)
or
F l = 1/2 (2000 kg) (9.81 m/s2)
= 9810 (N)
The force acting on the small cylinder in the jack can be calculated with (2d)
F s = (9810 N) 0.1
= 981 (N)
Fluid Mechanics
Gases and Compressed Air
Hydraulic Force vs. Pressure and Cylinder Size
Calculate hydraulic cylinder force.
Pressure
