Safety Relief Valves - Capacities vs. Pressure
Safety valves and maximum relief free air capacity:
Valve Diameter (inches) | Max. Relieving Capacity of Free Air (cfm) | |||||||||||||||
Gauge Pressure (psi) | ||||||||||||||||
50 | 100 | 150 | 200 | 250 | 300 | 350 | 400 | 500 | 600 | 800 | 1000 | 1200 | 1600 | 2000 | 2400 | |
1/4 | 12 | 20 | 27 | 33 | 38 | 43 | 48 | 53 | 61 | 70 | 84 | 97 | 109 | 128 | 147 | 160 |
3/8 | 17 | 27 | 36 | 44 | 51 | 58 | 65 | 72 | 83 | 95 | 115 | 133 | 149 | 176 | 197 | 215 |
1/2 | 20 | 32 | 42 | 51 | 59 | 67 | 74 | 111 | 129 | 147 | 177 | 205 | 230 | 270 | 304 | 330 |
3/4 | 37 | 59 | 78 | 96 | 112 | 127 | 141 | 176 | 224 | 232 | 242 | 346 | 386 | 423 | 474 | 518 |
1 | 58 | 94 | 124 | 152 | 178 | 202 | 224 | 248 | 286 | 324 | 390 | 450 | 500 | 586 | ||
1 1/4 | 84 | 135 | 180 | 221 | 259 | 293 | 325 | 352 | 400 | 443 | 509 | |||||
1 1/2 | 114 | 186 | 248 | 302 | 354 | 400 | 444 | 478 | 528 | 568 | 634 | |||||
2 | 189 | 306 | 410 | 501 | 592 | 668 | 741 | |||||||||
2 1/2 | 282 | 457 | 613 | 750 | 880 | 998 | 1114 | |||||||||
3 | 393 | 638 | 856 | 1050 | 1230 | 1398 | 1557 |
- 1 inch = 25.4 mm
The relief capacity for a safety valve depends on
- the relief discharge area
- the compressibility factor of the actual gas
- the temperature of the gas
- the geometry of the safety valve
A safety relief valve must be capable of relieving the capacity of the connected compressor(s) at operating pressure. Note that the relief pressure can not be set higher than the maximum rated working pressure of any equipment in the system. If the operating pressure is right below the relief pressure of the valve the valve may start leaking.
A "rule of thumb" is to set the relief pressure 10% above the working pressure of the system.
• Design of Control and Safety Valves
• Gases and Compressed Air
• Heating Systems
Factors of Safety - FOS
Factors of Safety - FOS - are important in engineering designs.
Heating Systems - Safety Valves Size vs. Boiler Power
Hot Water Expansion Tanks - Sizing
Required hot water expansion volume in open, closed and diaphragm tanks.
Low Pressure Steam Safety Valves - Capacities
Sizing safety valves after boiler output power in low pressure systems (kW and Btu/hr).
Pilot Operated Safety Valves in Liquid Systems
Calculate pilot operated relief valves in liquid systems.
Relief Valves - Length of Vent Pipes
Calculate length of safety valves vent pipes.
Safety Valves in Gas and Vapor Systems
Calculating relief valves in gas and vapor systems.
Spring Operated Safety Valves in Liquid Systems
Calculate spring operated relief valves in liquid systems.
