The emissivity coefficient - ε - indicates the radiation of heat from a body according the Stefan-Boltzmann Law, compared with the radiation of heat from a ideal black body where the emissivity coefficient ε = 1.
The emissivity coefficient - ε - for some common qualities of aluminum:
Aluminum | Temperature oF (oC) | Emissivity Coefficient - ε- |
Unoxidized | 77 (25) | 0.02 |
Unoxidized | 212 (100) | 0.03 |
Unoxidized | 932 (500) | 0.06 |
Oxidized | 390 (199) | 0.11 |
Oxidized | 1110 (599) | 0.19 |
Oxidized at 1110oF (599oC) | 390 (199) | 0.11 |
Oxidized at 1110oF (599oC) | 1110 (599) | 0.19 |
Heavily Oxidized | 200 (93) | 0.20 |
Heavily Oxidized | 940 (504) | 0.31 |
Highly Polished | 212 (100) | 0.09 |
Roughly Polished | 212 (100) | 0.18 |
Commercial Sheet | 212 (100) | 0.09 |
Highly Polished Plate | 440 (227) | 0.04 |
Highly Polished Plate | 1070 (577) | 0.06 |
Bright Rolled Plate | 338 (170) | 0.04 |
Bright Rolled Plate | 932 (500) | 0.05 |
Alloy A3003, Oxidized | 600 (316) | 0.40 |
Alloy A3003, Oxidized | 900 (482) | 0.40 |
Alloy 1100-0 | 200-800 (93-427) | 0.05 |
Alloy 24ST | 75 (24) | 0.09 |
Alloy 24ST, Polished | 75 (24) | 0.09 |
Alloy 75ST | 75 (24) | 0.11 |
Alloy 75ST, Polished | 75 (24) | 0.08 |
The relatively low emissivity coefficient makes aluminum a suitable product for limiting the radiated heat from a body. Its by example common to use aluminum coating in rescue and survival equipment for outdoor operations.
• Thermodynamics
Aluminum - Melting Points of Binary Eutectic Alloys
Al - Aluminum - binary eutectic alloys and their melting points.
Aluminum - Thermophysical Properties
Density, specific heat and thermal conductivity related to temperature.
Aluminum Alloys - Mechanical Properties
Mechanical properties of aluminum alloys - tensile strength, yield strength and more.
Mechanical properties of some common aluminum alloys.
Aluminum Channels
Dimensions and static parameters of aluminum channels.
Aluminum I-Beams
Dimensions and static properties of aluminum I-beams - Imperial units.
Cooling Mode - Heat Flux
Heat fluxes for various cooling or heat transfer modes.
Metals - Specific Heats
Metals and Alloys - Densities
Metals, Metallic Elements and Alloys - Thermal Conductivities
Thermal conductivities of common metals, metallic elements aand alloys.
Radiation - Surfaces Emissivity Coefficients
Radiation emissivity of common materials like water, ice, snow, grass and more.
Radiation Heat Transfer
Surface Emissivity Coefficients
Surface Radiation Absorptivity
Radiation surface absorptivity.
