Hydraulic Cylinder Area vs. Diameter
Areas for some typical hydraulic cylinders are indicated below
Hydraulic Cylinders - Area vs. Diameter
Cylinder Diameter
(in)
Cylinder Area
(in2)
1 0.785
1 1/2 1.77
2 3.14
2 1/2 4.91
3 7.07
3 1/2 9.62
4 12.6
4 1/2 15.9
5 19.6
5 1/2 23.8
6 28.3
6 1/2 33.2
  • 1 in (inch) = 25.4 mm
Hydraulics and Pneumatics
Hydraulic and pneumatic systems - fluids, forces, pumps and pistons.
Area Units Converter
Convert between units of area.
Hydraulic Cylinders - Volume Displacement
The volumetric displacement of hydraulic cylinders.
Hydraulic Force vs. Pressure and Cylinder Size
Calculate hydraulic cylinder force.
Hydraulic Oil Pump - Horsepower vs. Pressure and Volume Flow
The power required for hydraulic pumping.
Hydraulic Pump Motor Sizing
Motor size vs. flow rate, shaft torque, shaft power and hydraulic power.
Hydraulic Pump Volume Capacity
Calculate hydraulic pump volume capacity.
